Dale(MO)
02-24-2005 14:41:29
Re: Sorry, off topic- I'm in the market for a S/A in reply to Pete in central Va, 02-24-2005 04:40:41
I can't find any pictures, but I can tell you about it. 1979 International 2275 (stub-nose hood and doghouse in cab), 290 B.C. Cummins, 10sp. Fuller tranny, 24.5 radial rubber, 10ft. bed. The cab is getting some rust (looks like a '79 corn binder), the bed has rust on the upright side braces, floor is solid (I replaced most of it a few years ago). The list of new parts on the truck is as follows: new kingpins and bronze bushings, tie rod ends, springs, spring hangers, hanger pins and bushings, shocks, head gaskets, center head (reman), hoist cylinder (has scissor-type hoist). Also has factory air conditioning, but it isn't working (?). Glass is good, doors are tight and don't sag. Was a daily driver until a couple years ago. Needs batteries (I think I have some good ones found). Steer tires and back brakes may keep it from passing DOT - not sure. Rear tires are 50% and 95% (one pair probably hasn't got 1500 miles on them), recaps. Cab is brown, passenger door is white, bed is charcoal grey. Has pintle hitch. Air lines were plumbed to rear by previous owner, but I have never used it - the glad hands are gone. Not a truck to set the land speed record (about 62-65mph), but a good load handler. It's not the prettiest, but it was strong and dependable. I live in Missouri, so I don't know if you would be that interested - that would be a long trip home. If you are, email me a tdemily(at)hotmail(dot)com . Sorry for the long post. Thanks!
