VAC hydraulic pump
Jerry W
02-23-2005 10:41:41
I am thinking of running a hydraulic pump by mounting it to the old magneto drive coupler out of the front engine case. The reason for this is that I have a pump that will allow for independent power steering hydraulics and hydraulics for my loader at the same time.
My concern is that the gear is only 7/8" wide instead of 1 1/16" like the factory pump. The wider gear cannot be used on the magneto drive without a lot of work. The magneto drive shaft is actually twice as thick as the old pump drive shaft so that should not be a problem. Is this narrower gear going to be a reliability problem?
Jerry
BLR
02-26-2005 08:36:21
 Re: VAC hydraulic pump in reply to Jerry W, 02-23-2005 10:41:41
Jerry,
I have a VA with a loader that operates using the original case pump through a 4 spool open center valve. One thing that I did to keep the wear and tear on the pump and drive system was set the pressure releif valve in the control valve to release at about 450 psi. When I initially installed the open spool valve the relief was set well above the normal 800 psi operating pressure of the VAC hydraulic system. Even with the low 450 psi setting the loader will lift more than the tractor can carry. Bottom line to all this is you might verify the operating pressures and keep them as low as possible to reduce wear and tear on the gear.
Jerry W
02-26-2005 13:15:48
 Re: VAC hydraulic pump in reply to BLR, 02-26-2005 08:36:21
My concern was that the early 1949 Eagle hitch VAC's used this narrower gear and there must have been a reason that Case got away from it so quick.
I have decided that I am going to use it and maybe later I will make a wider gear when time permits.
The pump I plan on mounting to the drive has a 2500# relief pressure but I need that as I am using small diameter cylinders on the lifting frame but total work should be the same as far as the gear is concerned.
Jerry
Joe (Wa)
02-26-2005 13:47:50
 Re: VAC hydraulic pump in reply to Jerry W, 02-26-2005 13:15:48
The cam gear was also changed in mid 1949, I assume to accommodate the wider pump drive gear.
Joe
mj
02-23-2005 12:08:05
Only time will tell...Roger?
