new 530ck owner problems
newlander
02-22-2005 19:24:44
Hi- bought a 530ck two days after buying 20 acres- my first tractor. runs great- leaks lots of hydraulic fluid from rams!
used 46 fluid not 32 to slow leaks... noticed the fluid getting frothy or milky... surely not a good thing.
then, blew a hose sunday while pulling stumps/ building my road, and decided to drain system and replace filter. I still havent gotten my manual in the mail yet, so i found the "drain" at the bottom of the right hand upright- it gushed a brown dirty hydraulic fluid- took off filter- and Lo-and-behold! NO FILTER! I dont have any manuals for the machine yet and was wondering if anyone can give me some pointers on refilling and running my tractor? it needs to last me a long time... and I need to use it again immediately... I"m not sure if I got all of the fluid out- or if I need to. I hopefully ordered the right filter from NAPA- and I am hopefully using the right fluid..
any suggestions of help will be VERY appreciated- I need to move onto the land and stop paying rent ASAP- haha
sorry for the wordiness
Jim
jim239
02-23-2005 10:47:17
 Re: new 530ck owner problems in reply to newlander, 02-22-2005 19:24:44
prob not useful to drain it, if its leaking out so fast :) Just keep filling it till you have a chance to fix the bad leaks. The hyd system holds a lot of oil so you can leak a lot out before the backhoe stops working. Bursting hoses is a common problem on older machines. They are easy to fix so no big deal. If you break a new hose, you might need to check the line pressure.
BKahler
02-23-2005 02:57:13
Jim, I feel your pain! I popped a hose as we drove mind into the shop to do an engine rebuild. Haven't even had a chance to try and use it yet since I bought it.
Anyway, the owners manual has the following info on changing the fluid:
The Loader hydraulic sysem holds approximately 8 U.S. gallons of oil and the backhoe hydraulic sysem holds an additional 11 U.S. gallons. However, only aproximately 5-1/2 gallons of oil will drain from each reservoir as the lines, valves, cylinders, and pump hold oil. It is not necessary to drain the oil from these components.
"Checking Hydraulic Oil Level"
The loader subframes serve as reservoirs for the hydraulic oil. If the tractor is equipped with a loader only, just the right hand reservoir contains hydraulic oil. If the trator is equipped with a loader and backhoe, both reservoirs are used. Drain plugs are located at the elbow in the bottom of the reservoirs.
In order to obtain an accurate measurement of the reservoir oil level:
1. Have the tractor standing on a level surface.
2. Run the tractor until the hydraulic system warms up (reservoir warm to the touch).
3. Lower the bucket to ground level and roll it back.
Remove pipe plug "A" from the right hand reservoir and check the oil level. It should be even with the bottom of the hole. If the oil level is to high, it could overflow through the reservoir breather. If the oil level is too low, there is a possibiliity of starving the pump - causing foaming, overheating, and damage to the hydraulic system. "A" is the pipe plug close to the loader operating vavle on the side of the reservoir frame.
To drain the reservoir(s):
1. Have the Tractor standing on a level surface.
2. Run the tractor until the hydraulic system warms up (reservoir is warm to the touch). 3. Lower the bucket to ground level and roll it back.
4. Place the backhoe in transport position.
5. Remove pipe plug "A" from the right hand reservoir. "A" is the pipe plug close to the loader operating vavle on the side of the reservoir frame.
6. Remove the drain plug(s) at the bottom of the reservoir(s). 7. Remove pipe plug "B" from the top front of the loader frame arm. Using Case HiLo TCH oil or an approved substitue, fill the reservoir through pipe plug A" hole until the oil begins to run from pipe plug "B" hole. Replace pipe plug "B" and continue filling. Failure to remove plug "B" may cause a voide in the reservoir and insufficient oil in the system.
When the oil is up to level plug opening, replace plug "A": start the engine: and put each control through its operational cycle to be sure all air is out of the system. When all air is out of the system, check the oil level as indicated under "checking hdraulic oil level".
Sorry if there are any typos! Hope this helps.
Brad
Joe Gentile
06-20-2005 13:22:00
 Re: new 530ck owner problems in reply to BKahler, 02-23-2005 02:57:13
Hi there. OK, I'm new with the Case 530CK, and confussed about the information regarding draining and filling the hyd. on the machine. I have a loader and backhoe. On both sides of the machine, as you described are 3/4 inch pipe plugs. One at the top of each loader arm, and one at each side about half way up. I am draining the system. Does the system then hold approximately 5.1/2 gallons per side? Should I take off the top plug on each side and fill until the oil comes out each side plug? Someone told me the best way to fill this is to do the following, see if you agree. Remove the 3/4 inch plug from the top of the right side loader arm. This is the side where the controls are for the loader. Remove the 3/4 inch plug from this right side also. Keep in mind, I have drained both sides of oil. Pour in the oil at the top of the right side loader arm until it begins to come out the side plug. Here is where I am getting confussed. Once this right side is full, do I put back the side plug and then move to the left side and do the same?? Is it true then I need approx. 11 gallons of oil to refill the entire system? Should it take approx. 5 gallons to fill the right side, and another approx. 5 to fill the left side? Am I confussing you yet!! LOL.. There are also bleed plugs, I think like 3/8 inch pipe plugs at the top of each side of the loader arms. Should I loosen one of these to bleed the air out? Or, is it OK, to just move the pistons threw there functions, to rid the system of air? How about the Hyd.filter at the top right hand side? Is this a filter I can maybe get at my local Auto parts dealer? Sorry if I confussed you, but I want to make sure I don't damage the hyd. pump in changing the oil. Thanks for the help!!
newlander
02-23-2005 18:12:38
 Re: new 530ck owner problems/filter in reply to BKahler, 02-23-2005 02:57:13
one more thing- went out there after work to get to it... neither of the potential filters NAPA gave me fits... anything in there about the filter type? (hydraulic)
by the way- those are some GREAT pics!
Anees
05-07-2006 03:58:14
 Re: new 530ck owner problems/filter in reply to newlander, 02-23-2005 18:12:38
Filters of any type can be obtained from posting at [email protected]
Regards
Anees
BKahler
02-23-2005 18:50:32
Jim,
Below is the information I found on the baldwin filter site. Hope the link below works.
Baldwin Filters
Anyway, I found the following information for Baldwin Filters for the case 530CK backhoe with a diesel engine. If yours is gas then the oil and fuel filters might be different.
Vehicle : Off-Highway
Manufacturer : CASE
Make : Loaders, Skidders, Etc.
Model : 530CK Backhoe/Loader
Description : 530CK Backhoe/Loader w/Diesel Eng.
Lube B2
Hyd. PT435
Hyd. Pump (A10059) S423
Steering (A42242) P183
P. Fuel Sock (A35863) F961-C
Can-Type F.Fuel (A51346) BF838-F2
I've unhiden my email address, send me an email, I've got something for you.
Brad
newlander
02-23-2005 13:13:21
Thanks SO much to you both!
and particularly to BKahler- even with the typos it was useful. HAHA!
got the fluid ordered and will be ready to go this weekend.
again- cant thank you enough for the input1
