580D transmission
dan jefcoat
02-22-2005 16:55:47
stuck in 4th gear, cannot get loose prying through shift lever hole and transmission cover will not come off. It looks like the rail for 3 & 4 may have moved toward the front. the grooves on the rails at the rear of the transmission do not line up with the groove on rail for 1st and 2nd. Any suggestions?
Can I get into transmission to check rail from the drive shaft opening or is there an easier way?
jean Claude Marleau
02-23-2005 17:35:40
 Re: 580D transmission in reply to dan jefcoat, 02-22-2005 16:55:47
The only way to get at it is to remove your lever for the gear shift snap ring that hold it and through the hole you should be able to move the fork that is stuck. hope this can help .
