fuel pressure + vacuum gauges needed.
John Billington
02-22-2005 16:44:49
Does anyone know where I can find a fuel pressure and vacuum gauge for a 400 racine reproduction or nos ?? thanks John in IL
Patrick (Mich.)
02-23-2005 23:21:06
 Re: fuel pressure gauge in reply to John Billington, 02-22-2005 16:44:49
If the 400 diesels use the same gauge as the 30 series diesels, the part is still available from Case Corp. I recently purchased one for my 830 diesel; part #A8101, cost $26.31.
mike's600
02-22-2005 16:55:50
 Re: fuel pressure + vacuum gauges needed. in reply to John Billington, 02-22-2005 16:44:49
good luck, check with Don L 1507 433 -0073 mornings
Wayne J
02-23-2005 06:07:47
 Re: fuel pressure + vacuum gauges needed. in reply to mike's600, 02-22-2005 16:55:50
That makes atleast two of us i under stand that they are not available at all. i am also looking for the two fuel gages Hay John Seali anything on 400 diesel fuel gages. lets see if this helps. Wayne J
John Saeli
02-23-2005 10:22:31
 Re: fuel pressure + vacuum gauges needed. in reply to Wayne J, 02-23-2005 06:07:47
Hey Wayne: When CASE put the cabosh to my guage project, I sent some samples to Camboted. Nothing yet. Eventually it will happen. Thanks
Wayne J
02-23-2005 10:51:35
 Re: fuel pressure + vacuum gauges needed. in reply to John Saeli, 02-23-2005 10:22:31
Hay John saeli no chance of a 60 or so CASE amp gage. also who is doing the round 400 nose meadallion. Wayne J.
John Saeli
02-23-2005 18:57:50
 Re: fuel pressure + vacuum gauges needed. in reply to Wayne J, 02-23-2005 10:51:35
Come to think of it, CASE used a 60 AMP Guage in the combines. Any around you? For that Medallion: Roger Horbaker 301-223-9005
Glenn/Mn
02-23-2005 15:06:40
Throw my name on the list as well, Rodger Hornbacker has excelllant reproduction medallions, Forgive me for misspelling rodgers last name I am going from memory, try a key word search in the archives you should be able to find contact info.
