I'm Dropping the Shuttle on my 580 SE
Pete in central
02-22-2005 16:14:03
After research and input considered, I'm going to drop the shuttle on my 580 SE TLB. Talked w/case dealer. He said he can wrap up all soft parts and torque conv. for about $800. I wonder how crucial it is that I change out the converter, the symptoms point to the clutch pack/springs. The machine is good in reverse, but has no guts in foward. I'll have it out tomorrow night, and shotgun it in the eves this week, then re-install this weekend perhaps. Any pointers, input, or experience to consider is appriciated.
-Pete
agri-con
02-24-2005 02:12:51
 Re: I'm Dropping the Shuttle on my 580 SE in reply to Pete in central Va, 02-22-2005 16:14:03
when it comes to putting it back together-make sure the converter tangs are at 9 and 3 oclock,look thru the shuttle front into the pump and rotate pump tangs to 12 and 6 oclock makes installing a breeze.Just one tid bit-use grease to help hold the smaller pack supply seals on shaft end when you install it into planatary.These puppys sometimes can hanngup and tear on ya,lube your discs upon installation into drum-prevents dry burn upon start up.MAKE SURE THE RIGHT SNAP RINGS GO WHERE THEY BELONG=very important.
Pete in central Va
02-24-2005 04:46:36
 Re: I'm Dropping the Shuttle on my 580 SE in reply to agri-con, 02-24-2005 02:12:51
Got it, Thanks very much, lube is very good thing ;-)
-Pete
Greasey Hand
02-26-2005 06:34:13
 Re: I'm Dropping the Shuttle on my 580 SE in reply to Pete in central Va, 02-24-2005 04:46:36
I have new springs that work for the 580 CK check to see if the clutch hub are the same, Springs are $30.00 a set of 6. A new hub is $160.00 +
Pete in central Va
02-26-2005 19:27:37
 Re: I'm Dropping the Shuttle on my 580 SE in reply to Greasey Hand, 02-26-2005 06:34:13
Thanks very much Greasey for the offer. I'm actually just about done putting it back together. It really hasn't been a bad experience, except the hydraulic/deisel smell seems to eminate into the house from the work area. The wife dosent care for deisel too much.
Turned out that the TC was toast, which scored the charging pump, which didnt actually cause the symptoms, but had to be R&R'd none the less. They were the big ticket items that got the parts cost up to $800. The foward clutch plates (friction plates) were toast too, down to metal , as well as a scored "bellville spring". Thats what caused the loss of foward.
So the kit included all ext. seals, o-rings, friction & metal plates, gaskets, clips, seal rings, torque converter, charge pump, TCH (5 gal) and limited support for $856.25.
and 2 days of my work for the drop, tear down, clean/inspect, re-assy, and instalation.
PS for the archive, a guy (x-CASE authorized field mechanic, turned service manager of the previous company that was the Case dealer locally) had mentioned that... On the spool valve, the open part of the clip on the end closest the detent plate should be aligned to the notch in the spool body. If not, in time it will wollow out the notch, causing an inability to find neutral, and worse somtimes, cause the shuttle to remain in foward when switched to reverse, causing much more damage to the SB.
I would like to thank the group for all the support, and encouragment in the matter.
Thank you
-Pete
mEl
02-22-2005 17:54:30
You should have a service manual to tell you how to select the proper snap ring for the fwd clutch pack, there is a setup procedure and also a procedure for getting the shaft into the fwd clutches without damaging them. I know I will draw fire for this but this unit is just complicated enough that I have had to redo some that shade tree folks had tried to repair to no avail, there are tricks to holding the bellville spring in position while the unit is put in a hand press to compress it to get the snap ring in the fwd clutch drum. Also have had people put the bellville spring in backwards,not to mention cutting the little seals on the fwd clutch feeder tube when installing the fwd clutch assy into the output gear. If you can borrow a manual fine, but you are meassing with 800.00 dollars parts, do it right or you WILL be pulling it back out. PS, case recommends a new cooler(a flush should be ok) and remember, the trash from the clutches is probably out in the converter which acts as a large centrifugal filter and will work its way back to sump at some point in time, At the very least it should be removed and taken to a automatic tranny shop and cleaned internally and checked for internal end play. Don't mean to be a doom n gloomer but been there , done that, and got the tee shirt, there is no free lunch. Good luck, mEl
Pete in central Va
02-23-2005 18:06:39
 Re: I'm Dropping the Shuttle on my 580 SE in reply to mEl, 02-22-2005 17:54:30
Thanks mEl. I have a service book for an '89 580ck (im doing an '85 SE), but it seems to have it all good so far. Dropped the shuttle today, wasn't so bad, started at 8am and had it on the ground by 11am. Took it home and dis-assembled the box. All hard parts look to be good, but the TC was in fact toast. There was a thin metal piece just inside the lip of the spline hole that was loose, and looked to have rough edges. I will replace it, no doubt. I did read in the service manual, and like you said, there is a +- 1000's inch tolerance with the rings that must be right on the money, and I will pay close careful attention to not damage the seals during re-assy. I think and hope shes going to be alright. She's only got 2k hrs on her, and she acts like it too. I will post some pics later to.... www.littlebirdsoftware.com/case580se
Thank you and the group for your encouragement and support.
-Pete
