carb rebuild 411b
gary case
02-22-2005 06:45:58
iwant to rebuid carb on my 411b what is the best way or cani soak the whole carb? and what should be used? theres two rebuild kits shouls i replace everything? leaks when sitting and lopes alittle thanx gary
BobV
02-22-2005 12:44:21
 Re: carb rebuild 411b in reply to gary case, 02-22-2005 06:45:58
Gary, saw your post and have some info I'm restoring a 411B and the carb. on it is a Zenith G45719, 12255 when you find a supplier let me know I need a kit also, my opinion is clean everything with a carb. solvent and replace with as many parts that the kit comes with. Also adjusting the float and check it for leaks. A good way to check it is prepair a pan of boiling water and put the float into it, if there is a leak you'll see the bubbles coming out.
caseman-d
02-22-2005 12:09:36
On most overhauls on carbs you can get by with with just 2 gaskets and a needle and seat which is still available from Case, if you can come up with the zenith number I should be able to come up with a current number,
caseman-d
GARY CASE
02-24-2005 13:56:40
 Re: carb rebuild 411b in reply to caseman-d, 02-22-2005 12:09:36
CASEMAN ETHER I GOT A WEIRD 411B OR SOMETHING. BOBV SAID HE HAD A ZENITH ALSO. THE BOOK DOESNT REALLY SAY 411B, SAYS 400B, BUT I JUST WENT BACK OUTSIDE AND ITS GOT MARVEL-SCHEBLER AND THE LITTLE TAG SAYS TSX 749. WHATS UP WITH THAT???
case poor in pa
02-22-2005 15:52:28
[email protected] mite be of help. hes has me with his vast knowledge and resources
GARY CASE
02-24-2005 14:04:52
 Re: carb rebuild 411b in reply to case poor in pa, 02-22-2005 15:52:28
I SEE NOW IN MY BOOK THAT THEY USE BOTH. MY BOOK STARS WITH SER# BEGINING WITH 6095009 PARTS CATALOG R.I. A377 .
