Propane
Awhitaker
02-22-2005 05:53:06
When I try to fill my 830 LP, I'm only able to get about 30% into the tractor tank. Even with a full 250 feeder tank. What can I do to get more gas to the tractor tank? Do I need a bigger "mother" tank?
Would painting the "mother" tank a dark color help?
Or Should I look for a pump?
Jimmie D. Phelps
02-22-2005 20:41:50
 Re: Propane in reply to Awhitaker, 02-22-2005 05:53:06
Get a end that will relieve the main Vapor valve and put a pc. of pipe 3/4 about 10 in. long and bleed it that way .You got too screw it on only part way as full will shut off the valve. Also you could run for 30 mi. on vapor before filling. and than it will fill to about 60%. without bleeding. Fill at midday when the your fill tank is the warmest.
Larry806
02-22-2005 06:39:47
Are you opening the bleed off on the tractor tank?
Awhitaker
02-22-2005 11:57:30
 Re: Propane in reply to Larry806, 02-22-2005 06:39:47
Yes, the bleeder valve is opened when I fill. Never saw liquid except when we filled off the truck.
