900 CASE
KY CASE GUY
02-20-2005 14:56:16
I am getting ready to buy a 900 CASE and I want to be able to lighten it up to pull. The rear wheel"s are cast and I want to swap to a pressed metal wheel. How has anybody done this is there a adapter to buy,make, or whatever. Please help!
Jim McVay
02-21-2005 09:35:11
 Re: 900 CASE in reply to KY CASE GUY, 02-20-2005 14:56:16
I saw on this site where someone was making 9 hole hubs to bolt on the axles. My dads 900 will pull in 7500# with the cast rear wheels. I have 6 bolt hubs that will work on the front. Change out the rear cover to one off of a L or LA to lose weight and allow for a shorter hook point.
Mikes 600
02-20-2005 15:33:39
What weight class are you going to pull? What MPH are you going to pull?
Depending on how you are going to pull, putting on press steel wheels may be a waste of time.
