Case 580d Transmission cover
dan jefcoat
02-20-2005 10:29:35
stuck in 4th gear. can not get loose with screw driver thru shift lever hole, 1 & 2 side on rail ok. cannot remove cover after removeing 4 bolts. any suggestions
dan jefcoat
02-20-2005 13:14:14
 Re: Case 580d Transmission cover in reply to dan jefcoat, 02-20-2005 10:29:35
I have driven forward and reverse as well as jacking rear tires off ground. no luck
