switching uniloader controls
pepper boy
02-20-2005 07:30:20
I have a 1992 1845c uniloader. The control for bucket curl is set up so tilting the grip towards the center of the machine curls the bucket down and tilting to outside curls the bucket up. This is backwards to me because every one that I have used is opposite. The boom controls are fine. It seems to me that there is a way to reverse the control to make it operate like I want it to without a lot of trouble. Does anyone know how to do this. Thanks. Scott.
Can't even use my name
02-21-2005 04:57:04
 Re: switching uniloader controls in reply to pepper boy, 02-20-2005 07:30:20
On our 1840 the right hand side controlled the bucket, in and down made the bucket curl down while out and up made it curl up. Someone must have switched them before you got it.
pepper boy
02-20-2005 10:21:15
 made hose change in reply to pepper boy, 02-20-2005 07:30:20
went ahead and switched hoses on side of boom arm. easiest place to get to. works the way I want it to now but bucket curl down is real slow. Lost maybe a cup of hydro oil. I guess no way to bleed but maybe with use lines will purge themselves. Any ideas? Thanks. Scott.
pepper boy
02-20-2005 09:03:46
just swap hoses on bucket cylinders in front of machine? I guess I need to lower everything to release pressure? How much fluid will I lose? Will I need to bleed out air or anything? Thanks. Scott.
rgorange
02-20-2005 09:22:48
 Re: switching uniloader controls in reply to pepper boy, 02-20-2005 09:03:46
Maybe it is not as easy as it was on farm tractor loaders I have used! No, not on front... in the rear where hoses connect. Yes you lower bucket to release pressure. No tools needed. Press outer collar forward to release hose. Should not lose any fluid because there is a check valve. Be sure to wipe clean before reconnect.
rgorange
02-20-2005 07:54:25
Scott,
Have you tried swapping the 2 hydraulic hoses that control the bucket curl?
