Need power steering info to covert DI
Rodger Beaton
02-19-2005 17:03:48
I have a great big loader on a recent 1953 aquisition. the tractor runs great, but can't move the steering wheel. It has a great big bucket on the machine, will lift almost anything. But can't steer even with bucket empty. There was a great big weight box on the rear that is unattached. that probley made it a dangerous teeter toter? I would like to find someone that converted say a David Brown, or International steering piston and used the loader hyd pump with a reducer valve?
Dug G.
02-19-2005 17:53:13
 Re: Need power steering info to covert DI in reply to Rodger Beaton, 02-19-2005 17:03:48
I have a SI that was adapted with power steering for loader work. It had a couple brackets welded onto it, and a steering motor/pump/sensor? welded into the the drag arm. The motor thingy then ran to a cylinder monuted from the radius arm best I remember, to a tie rod. I still have the sensor/motor thingy mounted on there and the cylinder set aside. It didn"t have the pump (which mounted on the front of the crankshaft) with it). I can send you some pictures if you like, and can send you the pump and possibly the drag link and sensor/motor thingy if you can send me a good un-welded/modified drag link. Let me know, e-mail is unlocked. Dug
Rodger Beaton
02-19-2005 18:32:59
 Re: to dug G Need power steering info to covert D in reply to Dug G., 02-19-2005 17:53:13
I tried to send ya an email with a picture but it was rejected. here is my email [email protected] to send me some pics, I can send you soe pics back.
rodger
Dug G.
02-19-2005 20:39:21
 Re: to dug G Need power steering info to covert D in reply to Rodger Beaton, 02-19-2005 18:32:59
I will send you some pictures this weekend (at college right now), and e-mail you from another account. The SI I have was used at a junkyard for who knows how many years unitl it locked up, and any (if any) rear weights were removed with the pump). I"d be more then happy to send you the picks this weekend and if you want the parts all you have to pay for is shipping since I don"t need them. Dug G.
