VAC Steering
JPBoyd
02-19-2005 16:36:16
I have a VAC row-cropper. I repaired the worm wheel but cannot reassemble. It seems I am binding the worm gear with the worm wheel. Is there an alignment trick to reassembly?
mj
02-20-2005 20:33:32
 Re: VAC Steering in reply to JPBoyd, 02-19-2005 16:36:16
Try this.
Alberta Mike
02-20-2005 12:43:46
We'll assume that you did a good repair job on the worm gear and that's not the problem. I believe you can shim the worm gear on that steering shaft (between the upper end of the worm gear and the shaft) and then also possibly shim the cast housing that holds the whole upper steering assembly together. These shim(s) would go between that casting (which is held down with two bolts) and it's mount on the lower tractor.
Jboyd
02-20-2005 15:24:02
 Re: VAC Steering in reply to Alberta Mike, 02-20-2005 12:43:46
Ok-got the steering back together. I had the front axle 180 degrees off (I think). Now the Worm Wheel is angled away from the worm gear not towards it. That being said, I have 6-8" of play in the steering wheel before the front end moves. Anyone know where the adjustment is to reduce this? Little scary at high speeds on the road with that kind of play.
