Looking for Air Compressor Recommendation
rgorange
02-19-2005 16:02:01
One of these days I will be restoring an SC. So I will be doing some sandblasting and painting and will be buying an air compressor. It will be a good thing to have but will not get used every day after that. A tractor restoration book told me that there are all kinds of considerations (HP, CFM, tank size, etc). OK... we knew that.... but it did not go on to discuss any of them. I am interested in hearing about your experiences. I'm considering a Sanborn.... not sure if they are still made in Sanborn, MN as I think they have been bought by Coleman. So what should I look for? Will a 110v unit suffice? Will a portable unit have the capacity? How much HP and CFM? The book did say that the oilless units don't stand up and I can believe that you need lubrication. What do I need to remove the oil for painting and blasting?
Thanks, rg
K C in Ia
02-20-2005 09:10:29
 Re: Looking for Air Compressor Recommendation in reply to rgorange, 02-19-2005 16:02:01
Just bit the bullet and bought a larger compressor. 5 hp 220 volt, 60 gal. tank, single stage, belt drive, 16+ACFM @ 90psi. got an Ingersol Rand for just under $900. Made in USA according to tag.. Another I looked at was a CastAir, they're made in Minn. USA. Virtually same spec's & price but delivery was 2-3 weeks. Sure beats the little direct drive it replaced BUT cost over twice as much. So far I've not regreeted doing it though.
Jerry W
02-19-2005 16:13:39
I have a 5hp single stage Campbell-Hausfield with 75 gallon upright tank that I keep aired up 24 hours a day. It is perfect for what I need 99% of the time which is airing tires, bead/shot blasting and running shop tools.
This is not the best compressor for sand blasting but I do not do enough to warrant a larger one. I have another 50 gallon pressure tank that I can hook in if I need to do so.
The problem with sand blasting is that you want high volume lower pressure compressor and the normal shop uses higher pressures and lower volumes.
I break is needed every 10 or 15 minutes anyway.
Jerry
Dug G.
02-19-2005 18:00:25
 Re: Looking for Air Compressor Recommendation in reply to Jerry W, 02-19-2005 16:13:39
I have a 6hp sears 33-35 gallon horizontal tank that runs off off of 220, but is pretty portable that I use. It kicks on quite a bit, but as Jerry said, I take a break every 10-15 minutes anyway. It's portable and works great for the blasting work that I do. I made a heavy gauge 40' extenuion cord, and have 50' of hose if needed, and is great for my needs. Hope this helps.
Dug G.
rgorange
02-20-2005 14:21:58
 Re: Looking for Air Compressor Recommendation in reply to Dug G., 02-19-2005 18:00:25
Thanks for the info guys.
rg
