Help identify
Old Eb
02-18-2005 19:46:58
These were posted for sale on ebay - first one was called a WO - second one the guy had no clue but said it was 1 of 542. Your thoughts?
third party image
WO
third party image
830 CK Standard??
jon mn
02-19-2005 06:35:06
 Re: Help identify in reply to Old Eb, 02-18-2005 19:46:58
the bottom tractor is a 730/830 standard. my neighbor had one when i was growing up. they are fairly rare. it should have an 8 speed trans mition, no 3 point, and power steering.
dctom
02-19-2005 05:40:59
IT IS A DC-4 WITH SOME KIND OF EXTRA OIL TAKN MOUNTED ON FRONT GUY CANT TELL DIFFERENCE BETWEEN A C AND O TOM
Hey DcTom?
02-19-2005 18:01:59
 Re: Help identify in reply to dctom, 02-19-2005 05:40:59
Just curious what features can help distinguish a D from a DC-4? Is it the tire size? Thanks.
Dug G.
rgorange
02-19-2005 18:59:53
 Re: Help identify in reply to Hey DcTom?, 02-19-2005 18:01:59
Dug,
D was standard tread.
DC-3 had rear tread adjustment and offered choice of single front wheel or dual-wheel tricycle front.
DC-4 had rear tread adjustment and standard front axle.
DC-3&4 offered PTO, Motor-Lift, independent assisting brakes.
Dug G.
02-19-2005 20:49:00
 Re: Help identify in reply to rgorange, 02-19-2005 18:59:53
I was just curious as to what distinguishing features from the picture could tell between a D and DC-4. I can kinda see the brake linkage going to the right side, but can't tell if its going to a right and left side brake pedal configuration (like the VA-VAC series) or just a single pedal. I was just curious to see if there was any single traits. By know means did I mean to insult or doubt Tom's judgement (which I feel I may have by the wording) by any means, I just want to learn any discrepancies that can distinguish them. Dug G.
Don Rudolph
02-20-2005 10:51:20
 Re: Help identify in reply to Dug G., 02-19-2005 20:49:00
D's had 26" rear tires on a solid cast hub. DC's have 38" tires on cast wheels that can be moved to adjust rear tread width.
caseman-d
02-20-2005 10:36:59
third party image
The radiator and radiator cap tells you it's a D series tractor. What identifies it as a DC-4 is the adjustable rears and the non adjustable front end. VA series you can not see the radiator cap, sheetmetal is different and is a smaller tractor. Hopes this helps you.
Picture of a D.
caseman-d
n-d/?action=view¤t=100-0029d_IMG.jpg
caseman-d
02-20-2005 16:36:06
 Re: Help identify in reply to caseman-d, 02-20-2005 10:36:59
I had to try this again
caseman-d
">Link
hope it works this time
Dug G.
02-18-2005 20:37:22
First is a case D series, D or DI, not sure on the other.
