DC clutch shaft seal
buster padgett
02-18-2005 07:05:45
Can anyone help me find a source for a clutch shaft seal on a Case DC? Local dealer is trying but unable to help.
Thanks!
Camboted
02-18-2005 16:49:47
 Re: DC clutch shaft seal in reply to buster padgett, 02-18-2005 07:05:45
You can try the OEM seal, if you can find one, but the problem we found with a couple of tractors is that the hole was so worn out there was no way a seal would hold up. We had to bore the hole install a bushing, and then a modern oil seal. It really is better and tighter than the original, but a lot of work.
Paul f
02-18-2005 07:11:26
You need two (one for each end)I assume you have hand clutch
Old #O5086AB New #A26849 Clutch Shaft Seal CR# 9876 National# 470120
