695 case forward/reverse clutches
corey c.
02-17-2005 14:12:16
got a case 695 with mfd that slips in forward more so in reverse. Wont pull its self in reverse. Split tractor and took forward/reverse unit out and took apart. Found that the screws that hold the pistons together had backed completely out. Installed new pistons, all of the plates and disc's. Installed new seal rings on pistons and clutch shaft. When i blow air into the oil inlet of the carrier..it doesnt hold good pressure. The clutches seem to lock up when i put air to it and move the spool. Just sounds like it leaks to much. The ring lands on the carrier and shaft seem fair. I have taken the unit apart again to make sure that i didnt break the 3 seal rings,,they were ok. Is this leakage normal? Does the approx. 320 oil psi seal the unit good enough?
