VAC Head
MikefromIowa
02-17-2005 12:25:25
Well, Looks like I may have a problem with my VAC. I started it the other day and let it run for about 5 or 10 min. I haven"t run it all winter. It was hot about 210-220 according to the gauge. It never runs that hot, i am assuming that the thermostat stuck shut. but the big problem is that I noticed oil bubbling out of the carberator side of the head gasket. the right side is dry. i haven"t started it since (2 days). I did check the oil and it doesn"t look like any water in there. it didn"t smoke either.
I am assuming I have a blown head gasket. Is it as easy as it sounds accorinding to the book to remove and replace? Do I have to remove the rocker arms, or can it come off as a complete unit? Any help would be great.
Thanks in advance.
Mike
My wife is gonna love to spend money on a 57 year old tractor :-/ oh well, she"ll either get over it or not.
MikefromIowa
02-18-2005 04:46:51
 Re: VAC Head in reply to MikefromIowa, 02-17-2005 12:25:25
thanks for all the reponses. I'll check and see if the head is still torqued correctly(that will give me an excuse to buy a torgue wrench).
I'll keep my fingers crossed.
mike
Joe (Wa)
02-17-2005 13:26:26
No you don't really have to remove the rocker arm assembly just back off the adj nuts and pull the pushrods so they don't get bent, you may have to backoff the rkr arm fastners or turn the engine to get them all out. Unbolt the carb & water elb, pull temp gauge thermocouple and lift head w/manifold straight up. Torque the head back down before installing pushrods again.
Having said that, why not pull the rkr asm? Only 2 bolts and a stud nut, just lift the asm holding the ends together so it doesn't come apart.
If the tractor water level was low below the top of the water pump it may have been air bound. There is no bleed hole in the pump housing and the little bleed hole in a closed T-stat impledes the flow enough that a slighty marginal but otherwise serviceable pump is incapable of expelling the air before the engine overheats. Takes several starts and cool down periods sometimes. I drilled & tapped the pump hsg for bleeders on my VAC, 310, & 311B.
Joe
CASEPOWER
02-17-2005 13:05:51
I wouldn't pull the head yet!! It is normal for oil to be absorbed into the gasket. The heating caused it to bubble. I would see if there is another cause for the heating before pulling the head. If there is no oil in the water and it's not blowing steam or white smoke, then your problem may be much simpler.
C. Amick
02-17-2005 14:06:08
 Re: VAC Head in reply to CASEPOWER, 02-17-2005 13:05:51
I agree with Casepower. But even if you don't find any coolant where it shouldn't be, you might want to check the torque on those head bolts. If the oil has oozed out of the gasket, it might have caused things to loosen up.
