sc brake seal replacement mistake
jstpa
02-16-2005 20:31:32
I replaced the brake seals on my 52 sc this week. I tried to go by the manual, but the differential fell on the right side. Now when I try to put the right side bearing carrier back on it wont go. It also looks like the left side has moved about 3/16" to the right. Looking at the book my guess is that my left side differential is not lining up with the planetary gears on the drive gear. Is this something I should be able to line back up without tearing the transmission apart or did I make myself alot of work. I am not sure on the terminology of the parts I just described so bear with me if I called them the wrong name. Any advice is appreciated. Thanks jstpa
Camboted
02-17-2005 00:52:51
 Re: sc brake seal replacement mistake in reply to jstpa, 02-16-2005 20:31:32
My experience is with DC's, but they are similar. What I believe has happened is that your differential gear and sprocket has slipped away from the pinion due to the wight of the chains. Those gears slide on the differential shaft and you should be able to push them back in place. Lift it in the general position and put a rag, then a pipe wrench on the shaft, and gently wiggle it back and forth a little. I believe it will slide back in.
It would not be a bad idea to tighten your chains. Every tractor I have pulled apart has had loose chains and one had ground groves in the bottom of the casting they were so loose. LOL!
