PTO guard
Jim Evans
02-16-2005 20:12:58
Does anyone have a picture or can they describe the tubular PTO guard for a SC? This is the guard you are supposed to use on the PTO shaft if you are doing hydraulic or motor lift work to protect you against the exposed PTO shaft. I would like to build one but I need details of how it was retained on the tractor. I would assume that nearly all of the original ones were quickly thrown away.
Jim.
caseman-d
02-17-2005 17:12:52
 Re: PTO guard in reply to Jim Evans, 02-16-2005 20:12:58
I show part number O8794AB and that changes to a A20483. I never checked to see if the number was good or not.
caseman-d
vac400
02-17-2005 06:07:48
Jim,, In my case 400 parts book it gives this part number 087944B Tubublar, PTO Guard.
Hope this helps, you can go to the case dealer and they will bring it up for you.
Jerry
vac400
02-17-2005 06:06:47
Jerry
neale cloyd
02-17-2005 04:55:02
I visited a case friend yesterday and lo and behold he is doing an sc----started to leave and said 'look here I even have this cover'It was the cover you are talking about----It is a cast piece which bolts to the studs which the fan shield mounts to. The tube part which covers the shaft is pressed into this cast.It also has the top link support cast into it, much like the racine 400s.This piece is not for sale but I can get pics----Neale
Camboted
02-17-2005 03:09:32
third party image
The original shield was a two piece unit. You may still have the base on your tractor. The picture is of an exact original reproduction wich is available from:
John Saeli: [email protected] or
Don Rudolph: [email protected]
Jim Evans
02-17-2005 04:09:33
 Re: PTO guard in reply to Camboted, 02-17-2005 03:09:32
Ted,
The shield I am talking about is a tight fitting cylindrical shield that covered just the PTO shaft. I will post a picture as soon as my photo site starts working again. Deere used a clamshell shield in this location. The purpose was to keep your clothing out of the PTO shaft when no driveline was hooked up.
I am not able to access the tractorshed site to look at your picture? I get a 403 forbidden error, even if I try to access the home page.
Jim
Camboted
02-17-2005 05:48:34
 Re: PTO guard in reply to Jim Evans, 02-17-2005 04:09:33
Yup, I know what you are talking about, It looks like a soup can with the ends cut out, not the pto top link, cover as described above. Every farmer I knew took them off and never put them back on. My dad had a NOS (took it off the day the tractor arrived from the dealer in 1951), it hung on the shed wall for 40 years and finally went to the junk yard.
Jim Evans
02-17-2005 17:18:29
 Re: PTO guard in reply to Camboted, 02-17-2005 05:48:34
Ted has it figured out. Here is a picture from the manual. I would like to know how they were mounted to the bracket in the back. I assume they clipped on somehow without using tools.
Jim
Neale Cloyd
02-17-2005 20:15:40
 Re: PTO guard in reply to Jim Evans, 02-17-2005 17:18:29
I left out an important piece of info-----The SC PTO shield I spoke about in my 1st post was for a foot clutch,live pto,eagle hitch SC tractor,Sorry for the lack of detail and no this cover is not like the racine 400. Neale
