need vac parts
Leon B
02-16-2005 17:35:13
Every year our Knights of Columbus council resores an antique tractor to raffle off in June. I am an AC man but this year a 48 vac was donated to us. I know very little about these so all help is appreciated. The tractor is disassembled and according to the service manual we need pto lever and sheild, themostat, the inner air pre cleaner, head bolt torque wrench, the spring under the seat, steering drag link, hyd cyl and linkage off of valve body, oil fill cap, and engine side dust cover.If anyone has these items or know where to get them it would be a big help. We are in the St Louis Mo. area. I have been looking at VAC's in the archive and learned alot already. Looking forwrd to your reply. By the way raffle chances are ten dollars each.
KENT
02-17-2005 12:49:39
 Re: need vac parts in reply to Leon B, 02-16-2005 17:35:13
I HAVE THE DRAG LINK OR TIE ROD WITH PITMAN ARMS FOR A VAC LISTED ON EBAY # 3874000103---THANKS
KENT
Keith-OR
02-16-2005 18:55:26
Torque wrench, I used an old pointer type torque wrench and went to second hand store found a craftsman 11/16 socket, ground to down so it was only 1 1/16 long, this worked really great.No special high $$$$ tools to buy. Also I found a therostat of right temp. ground it down to the inside diameter of upper hose and put a clamp on hose to hold it in place. Dan Buckert has PTO cover(sheild)and spark plug cover 217-847-2690
HTH....Keith
Lincoln
02-16-2005 18:23:33
There seems to be quite a few VAC parts on Ebay right now.
