Case LA wheel color
GV47LA
02-16-2005 07:54:13
Can anyone tell me the correct color for wheels on my Case LA? I have not seen any info in the book Full Steam Ahead on this subject. Also, has anyone used powdercoat on their wheels, and how does it hold up in use? Thanks.
Steve-MN
02-17-2005 16:36:48
 Re: Case LA wheel color in reply to GV47LA, 02-16-2005 07:54:13
Powdercoat would hold up fantastic. Very scratch & chip resistant. Polyurethane would be next. The original was enamel or alkyd. They will fade & are more easily chipped or scratched. The advantage of enamel is that it can be easily repaired.
Many heavy equipment manufacturers use almost exclusively Poly. Powdercoat requires uniform heating & it's hard to do on equipment that has thin & thick steel, so it's not used much except in the piece part stage.
Hope this helps.
Steve
Engineer20
02-16-2005 09:55:50
Rims are galvanized and wheels should be same color as rest of tractor.
