Next Question??
JGarner
02-16-2005 05:42:49
Thanks very much on the 311 vs 411 difference. Now this question will probably raise some contraversy. Just as a gut instinct I have never trusted an "automatic" transmission in a working tractor. This question has probably been asked before, but how reliable is a used COM from late 50s early 60s vintage? I have been looking for standard transmission tractors (20-40 hp range, early 50s eagle hitch to mid 60s eagle hitch). Am I limiting myself in my search? How trustworthy is the COM and how costly is it to repair? Are COM parts even available vs the standard triple range gears at salvage yards?
John Saeli
02-16-2005 11:45:51
 Re: Next Question?? in reply to JGarner, 02-16-2005 05:42:49
Like DKASE said, they are a very durable unit. Like anything else on the tractor, it's over 40 years old though. They are expensive to re-build.
DKase
02-16-2005 07:53:56
It is basicly the same transmission with a torque converter drive rather than a clutch. It has a manual lever that locks up the converter so it does not build up heat when pulling for extended periods. It operate it takes some getting used to. It takes a little common sense to drive. Very few people would operate the engine in their car at full speed and drop it in drive, but they seem to think it is the proper thing to do with a tractor and blame the tractor when it starts with a jerk. I don't think they are any more trouble some than a clutch. Just idle them down and dump the clutch like you would put a car in drive and speed the engine up. It will start to move just as smooth as a car moves. I'm sure lots of other guys will post their 2 cents worth. DK
JGarner
02-16-2005 12:23:19
 Re: Next Question?? in reply to DKase, 02-16-2005 07:53:56
Going to show my age here, but what you are telling me is that the COM is like the old early 50s cars with a fluid drive and what my folks called a semi-automatic transmission. You only needed the clutch when putting it in first gear and reverse. The rest of the gears you just shifted and when you came to a stop light you just applied the brake, although when starting again the clutch was depressed to shift to first gear.
The COM requires the clutch when shifting gears, but you can idle back and come to a complete stop with the breaks and start again by just drepressing the throttle.
How can you tell if the COM is in good working order if there is no throwout bearing to make noise or clutch to slip? My guess is that the torque converter is the costly item. Is it still available? Can one be rebuilt?
Lincoln
02-16-2005 14:11:37
 Re: Next Question?? in reply to JGarner, 02-16-2005 12:23:19
The COM isn't quite like the fluid drive cars. You still need to use the clutch to shift between gears, and it works best to idle down between gear shifts. The problem most people have is that the torque converter does not stop completely when the pedal is pushed in. This makes it hard to get into gear unless it is idled down. We've had one for 29 years and have had no problem with it.
