VAC 14 hydraulics.
Hey Joe(WA)
02-15-2005 20:29:51
Joe, is the hydraulic reservoir in the torque tube, independant of the transmission and rear housing? seems as someone has over filled the trans, level is way up on tip stick.
Thanks...Keith
Joe (Wa)
02-15-2005 20:55:06
 Re: VAC 14 hydraulics. in reply to Hey Joe(WA), 02-15-2005 20:29:51
Yes Keith you are right, torque tube and transmission sumps are separate. Division is where the torque tube bolts up to the front of the transmission.
The torque tube oil can leak into the transmission via the drive shaft seal or its retainer gasket. Also below that seal is the end cover for the countershaft with a gasket that can leak but not likely. The drive shaft seal is a double lipped seal that may have been discontinued by Case. You may be able to get 2 single lip seals in there tho. A poster named Augie was changing the seal a few weeks ago and can provide better info than I can on that.
Before you do anything don't forget to loosen the drain plug on the transmission and check for water, maybe you'll get lucky and find that is the high level problem.
Joe
Keith-OR
02-15-2005 22:02:05
 Re: VAC 14 hydraulics. in reply to Joe (Wa), 02-15-2005 20:55:06
Thanks Joe and Augie for the info. Will check tomorrow on the water in trans. But really think they put hydraulic oil in the wrong fill plug.I had to rebuild the hydraulic pump, was pumping hydraulic fluild into crankcase. Again thanks.....Keith
Augie
02-15-2005 21:10:54
You are correct. The front mainshaft seal is discontinued at the Case/IH store, and it doesn't cross to CR, National or anything else.
A pair of CR12456 or CR11800, or one of each, will fit nicely into the front mainshaft bearing cap.
