Hello, I have a friend that is having trouble with his starter. He has a Case Terratrac model 320 engine serial number is VAB11990, frame serial number is 3004920. Casting number on engine is VT-120, casting number on head is VT-148.He bought this crawler, drove it off the trailer, removed the tracks to replace pins and bushings, removed the starter because one of the two ears was broken off. He had the starter repaired and now he is convinced that the gear on the starter drive is not the right one. The gear was never removed when the ear was repaired. Benchtesting the starter shows no problems, however it will only turn the engine about 3/4th of a full turn, then when you try again it will turn it 3/4ths again. I think I know what the problem is, but don"t want to rule anything else out. He has not bolted a battery in, he is using jumber cables from his truck to the starter terminal. My opinion is that he is not getting enough amperage to the starter. I"m afraid he is going to burn up the starter. Someone please help! Can somebody help me identify the engine as well? Thanks in advance, sorry for the long post! Steve in Arkansas fcinsrc at sbcglobal dot com
