Water in Exhaust
CoreyG
02-15-2005 16:16:44
I'm interested in purchasing a tractor(Case 5140) that has been stored outside in the weather. How will water from the rain effect the engine.
C. Amick
02-16-2005 06:00:12
 Re: Water in Exhaust in reply to CoreyG, 02-15-2005 16:16:44
Does it have a vertical exhaust stack? If so, water could have gotten into the cylinders and frozen and cracked a sleeve. Is there coolant in the radiator? Drain a little oil out of the bottom of the engine oil pan to see if there is any coolant in the oil. If it hasn't been started in a while, you could also have stuck valves and/or pistons.
