Case 311 throttle stuck
FreddyK
02-15-2005 01:05:11
The throttle lever on my Dad"s Case 311 won"t move. It was working, but has been very stiff for a long time. Then last week it got stiffer. He determined that the problem is right at the dash. There appears to be some kind of clutch assembly where it goes through the dash. He couldn"t get it apart, so he put some penetrating oil on it. It loosened up a little, so he let it set for a hour. Then it froze tight. Putting a pipe wrench on it won"t even move it. Anybody have a tip? The tractor isn"t usable without throttle control!
Joe (Wa)
02-15-2005 09:37:31
 Re: Case 311 throttle stuck in reply to FreddyK, 02-15-2005 01:05:11
Pull the battery out and look up in there. You will see a round plate with a cork disc that is held in tension on the support by a spring located on the throttle rod.
Spray some PB Blaster on the cork to wash out the rust and let it soak and then work the throttle back and forth. Take care with force on the lever, they break quite easily and are scare as hen's teeth.
Joe
FreddyK
02-15-2005 11:00:25
 Re: Case 311 throttle stuck in reply to Joe (Wa), 02-15-2005 09:37:31
So that"s how you get at it. Thanks for the tip.
Now, I"m kinda dumb here. What"s PB Blaster? I"ll have to pass this on to Dad, and he will ask and I don"t know the answer!
Buncha thanks.
Joe (Wa)
02-15-2005 11:11:44
 Re: Case 311 throttle stuck in reply to FreddyK, 02-15-2005 11:00:25
PB blaster is similar to penetrating oil but really good in disolving oxidation. You can buy a spray can at almost any auto parts store, Napa, Wall-mart, etc.
The problem with the friction assembly is that the cork friction disc has deteriorated and there is rust build up between friction pad and mating support plate.
Joe
FreddyK
02-20-2005 20:31:24
 Re: Case 311 throttle stuck in reply to Joe (Wa), 02-15-2005 11:11:44
Dad reported tonight that the throttle works again. Your info did the trick.
