You can still get parts for your VA, but...
Dale Olson
02-14-2005 13:31:42
They are not cheap.
With the front wheels going in eight different directions at once, I figured it was time to replace the kingpin bushings on the front axel on my 1948 VA. Well, they are still available from the dealer, but at a little over $15.00 each, they sure ain't cheap. Still, it's worth $60.00+ to me to be able to point the tractor where I want it to go again. The other issue I need to address is the "clevis-style" tie rod ends, the wear on the pin and in the hole of the clevis and arm on the front spindle is another point of loosness.
I think I might try smoothing the pin out, brazing up the holes and drilling them back out to the new size of the pin. Any thoughts??
C. Amick
02-15-2005 13:35:08
 Re: You can still get parts for your VA, but... in reply to Dale Olson, 02-14-2005 13:31:42
I've repaired worn holes where pins fit in sickle bar mowers by building the openings up with brass and re-drilling the hole. I don't see why it won't work for your applicaton.
