Question for Case folks on general needs
JCH
02-14-2005 10:48:03
Looking to buy a CASE for a small hobby farm. Main needs are to plow snow in the winter, move a few round bales around in the winter for the horses, no till drill a pasture (one time only), and brush hog. Would the CASE DC be a good tractor for this purpose? Dependable? How easy are parts to find?
C. Amick
02-15-2005 10:20:58
 Re: Question for Case folks on general needs in reply to JCH, 02-14-2005 10:48:03
If you go with the DC, I would want one that has at least a hydraulic lifting bail in the rear that could be used for lifting hay bales and operating a snow plow. Those lifting bails can be converted to a 3-point hitch, if you know a good metals fabrication guy. Money wise, it's probably going to be less money than any other tractor of that size. Used and new parts are available.
dbb62
02-14-2005 22:06:16
I think too much tractor is always better than too little. Nice looking 830 diesel on ebay right now for $4500. It will do everything you mentioned and more. DC is a great tractor, but you would have to be picky about the one you buy. It would need to be a latter tractor with hydraulics, eagle hitch, etc.
caseman-d
02-14-2005 20:34:24
JCH,
What do you have for acers??? From what I'm reading is I would look for like a 400, 700, or 800. Thats a good midsized tractor for a loader, eagle hitch, hydralics, power steering. If you still thing you might need something bigger you might look at a 930, plenty of power to push snow, handle a loader. Might be on large size for bushhogging. I just think you would be a lot happier with something a bit bigger than the DC. Unless you have the 54 model DC you are bound with a hand clutch which I think hinders loader operations. caseman-d
oliver farmer
02-14-2005 17:55:22
A DC won't pull a no-till drill, you might have to hire that job out. I am not sure it is real good with a round bale, you might be able to work something out for the eagle hitch, or put a loader on it. For other work around the farm it should work well.
mj
02-14-2005 15:55:37
How about a VAC with adjustable wide front and Eagle hitch? Ought to be just right.
John H-WI
02-14-2005 15:24:19
Case DC is an iron horse, just take care of it and do the maintenance thats required. Big enough to brush-hog and your other duties. When I was still home the neighbor mounted a v-snow plow of a milk truck on his DC and rigged a scrapper on the back so he could do his long driveway. Worked great.
JGarner
02-14-2005 15:19:53
DC is a pretty good size tractor for a hooby farm of your description, VAC or SC would be more like it. As per my question over the weekend, parts for these tractors seem to be getting more plentifull all the time a number of our forum say.
If you want a big ole DC I'd say got for it. My dream is to have a collection that includes an LA Case, John Deere R and Farmall W-9. Just a pipe dream though, I like big old iron!!
