In line fuel filters for the old CASE
Greenfrog
09-10-1999 19:51:17
The old CASE has a sediment bulb fuel filter. The local tractor repair auto parts store tells me that i should put in an inline fuel filter since the sediment bulb wont take out todays gasoline "particles". they say that there are small sandy beads of "stuff" in the gas that erodes away the needle valve seats and other parts of the old carbs. is there any truth to all of this? i am sure the inline filter wont hurt anything but it does take away fro the original stock appearnace of the tractor. they said hide it up under the tank or hood somewhare. it will last a long time.....25000 miles of an SC case!!!!ha ha.
thanks in advance
Greenfrog
09-18-1999 19:37:52
 Re: In line fuel filters for the old CASE in reply to Greenfrog, 09-10-1999 19:51:17
Thanks for the info Jack. Click on the Greenfrog and the email is there.
jack
09-18-1999 17:35:55
I have an old DB Gas model (885G) tractor. Filtering gas for these is a problem. The carb on these three cyl engines are sooooo sensative. I installed a universal inline filter which I purchased at an auto parts store. It helps a great lot but I am still looking for something better yet. Looks is not something that you can be too choosy with your tractor. Priority is to get and keep the fuel clean.
The filter I've used has been on my machine for several months and it just played out today. It had a lot of grime, rust and some water in it. Yet it is not a water filter.
Send me your email address and when I come up with something satisfactor I will contact you. I plan to do this next week.
Good luck: Jack [email protected]
Rob
09-10-1999 20:09:33
I have an inline filter on my '58 511B. Better safe than sorry.
Chris Vangel
09-10-1999 22:07:14
 Re: Re: In line fuel filters for the old CASE in reply to Rob, 09-10-1999 20:09:33
While 'better safe than sorry' is a good thing to go by, if you insist in your 'original equiptment only' attitude (as I probably would) you should be able to take comfort knowing that todays' fuel must certainly be cleaner than the fuel sold when your tractor was designed. This being the case, I don't see how these 'particles' could target certain parts of a carb. When taking apart a modern auto carb, I do see this silt(for lack of a better name) in the bottom of the float bowl; however, I havn't seen it do anything other than sit there. The choice is yours.
