Dist. timing rotor location
BobV
02-14-2005 06:59:14
I'm tring to solve the position of the rotor on a 400B I have three manuals,a copy of the J.I.Case service manual & I&T Manual & the operators manual none of these shows where the rotor points at TDC. The dist. is in the motor and when #1 is at the top and the cam&crank marks are matched the rotor points to the back or towards the flywheel I think its 180 out some help would be appreciated.
BobV
02-15-2005 06:23:13
 Re: Dist. timing rotor location in reply to BobV, 02-14-2005 06:59:14
Thanks to all of you for the response to my question on dist. timing. I read the discussion group for Case everyday and I have learned so much, thanks to YTMag also for this web site.
Joe (Wa)
02-14-2005 12:08:12
Bob, The crankshaft makes 2 revolutions while the distributor rotor is making 1 rev so the timing mark will line up with the pointer either when #1 or #4 is TDC on the compression stroke.
The engine can be correctly timed with the rotor pointing ballpark @ 12, 9, 6, or 3 o'clock provided the #1 cylinder is TDC on the compression stroke and the firing order is in sequence.
Having said that, the factory �distributor attitude� of most older engines is to install the distributor so the rotor is under the tower that is nearest in a straight line to the #1 spark plug and that will be ballpark 3 o�clock on this engine.
The distributor drive gear is helical so when installing with #1 TDC on the compression stroke, start the gear mesh with the rotor between 1 & 2 o�clock. When the drive gear is in full mesh the rotor will have turned CW to ballpark 3 o�clock. Turn the distributor head until the points are just opening in the CW direction and the rotor is still under the #1 wire tower terminal. Install the remaining plug wires in firing order CW. That will be close to spark @ 0� TDC. You probably need BTDC, so use a timing light to tweak it in.
Joe
DKase
02-14-2005 07:26:12
Make sure you are on the compression stroke! If you are on the exhaust stroke it would be 180 degrees off.
dctom
02-14-2005 07:24:02
sounds right 180 out pull dis and move 180 ahead
