Thermostat for Case 500 Diesel
Walter
02-13-2005 18:41:43
I'm having trouble getting engine temp above 165 degrees unless I cover the radiator. I think I have a bad thermostat but I'm told they are obsolete for this tractor. Any ideas on where I can get one or will one from a 930 fit?
Kelly MT
02-14-2005 20:07:10
 Re: Thermostat for Case 500 Diesel in reply to Walter , 02-13-2005 18:41:43
Hi Walter, I had the same problem finding a thermostat. It seams to me they ran around $100 bucks if you could find one. I went to NAPA and bought a truck thermostat that matched the flow rate for the Case motor and turned a piece of aluminium down to match the difference in diameter. I also put a brass restrictor in the by-pass line drilled out to 1/2 inch. The 500 parts manual shows a set up like this that Case sold. Also search this site, a fellow back East has also done this. PK
