430 Polarity
shovelman
02-13-2005 05:29:45
Does a 430 tractor have a negative or positive ground system? I just picked up a 430 and the wiring is very cobbed up and it is not charging. It currently is set up 12V negative ground and I suspect the polarity is wrong. Unfortunately, I have no manual to refer to.
My 411B is 12V positive ground. I wasn't sure if the 430 was the same.
Any help will be appreciated.
Thanks,
Scott Goff
Tom (Ks)
02-13-2005 12:44:10
 Re: 430 Polarity in reply to shovelman, 02-13-2005 05:29:45
On gas tractors before SN 8233766 are pos. ground and diesels before SN 8232882. All newer ones are neg ground.
clayton zimmerman
03-23-2006 17:58:11
 Re: 430 Polarity in reply to Tom (Ks), 02-13-2005 12:44:10
Hi my 430-440 has a high SN# starting with 83 it came as a negative ground and wouldn't charge so I switched it to a positive because the book said positive ground and had the generator rebuilt and a new regulator I just put it back on and no charging. How hard is it to switch everything back to a negative charge system? Do I just have to reverse the polarity on the regulator again?
shovelman
02-13-2005 15:55:33
Thanks for the help!
Scott
