Lift on DC
Dan in Ore
02-12-2005 17:33:44
third party image
I looked a 1949 or 1950 DC today and have a question about the lift system. I have never seen one of these and was curious how it works and what it is called
JDB
02-15-2005 10:18:35
 Re: Lift on DC in reply to Dan in Ore, 02-12-2005 17:33:44
Looks to be a 49.
Single spool hyd valve.
Doesn't look like it ever had Eagle hitch.
It doesn't look like it has any of the brackets for the Eagle hitch.
JGarner
02-13-2005 09:44:58
Our 53 SC looked like his except for the extra outlets for the Eagle hitch pick up cylinder. Only difference is ours weren't plugged off, they had hoses hooked to them that ended in the female remote hyd. quick disconnects which were mounted up under the seat.
Larry Martin
02-12-2005 18:51:28
It is a standard low pressure hydraulic system of about 900 lbs. They had a mounted cylinder that operated the lift bail and you could also pie them up es a remote.
L.Lamp
02-13-2005 12:17:13
 Re: Lift on DC in reply to Larry Martin, 02-12-2005 18:51:28
The pump is a two way system that will power a two way cylinder in either direction. Looks like someone could not find a plug and screwed a bolt into the right side as pictured. Not good, since the threads could be damaged. The swivals on each side of the pump can still be had at your Case-Ih dealer. You will need to find a lifting bail and cylinder to replace the parts that belong on the tractor.
