400 case
kevin in va
02-12-2005 05:07:08
There is an auction coming up for a 400 case.what would be the value range on this ? the tractor is in fairly rough cosmetic shape but running.We had one when I was a kid.Any help would be appreciated.Thank you
KC RICHARD
02-12-2005 12:05:33
 Re: 400 case in reply to kevin in va, 02-12-2005 05:07:08
around here running 2000 IVGC 3000 TO 3500
Kevun in Va
02-12-2005 19:25:19
 Re: 400 case in reply to KC RICHARD, 02-12-2005 12:05:33
Thank You all for an idea on what I should be looking to spend.
JRT
02-12-2005 07:58:34
I have one which is a wide front deisel that I bought about 10 years ago for 900.00 but that was a steal. It was in good mechanical shape but the tin was real rough. It was worth closer to 1500 I would guess. I have seen where people are asking 2500 for them in real good shape. I still have mine and it is a great old tractor. I use it for square baleing hay and it is is real smooth for that job. I really like the 8 speed on one stick after I finally got use to it.
Coloken
02-12-2005 07:03:24
FWIW; one coming up at auction here the 21st. Its been to see the elephant several times but still runs. Those things were hard to kill. I would think the tricycle front would hurt the price. 400s make good loader tractors if you can learn the 8 speed, one stick shift. I ran one for years with a 8 bale acumulator fork.
Camboted
02-12-2005 05:38:08
Case tried hard to confuse us all by marketing two completely different model 400 tractors in the 1950's. The first was a larger, 38" tire tractor around 50hp, the second was a smaller, utility size tractor, about 35 hp. So, which one are you talking about?
Dean Duncan
02-19-2005 17:02:57
 Re: 400 case in reply to Camboted, 02-12-2005 05:38:08
you seem to know case i am looking at a 401 diesel any thing you could tell me would be nice i have found nothing. narow frot end runs needs water pump he is asking 800 any input would be nice thanks dean
kevin in va
02-12-2005 06:10:36
the larger one ,tricycle front end.8 spd
