Early 700 Series Case Tractors
John C.
09-10-1999 06:00:40
Does anyone out there have any experience with the early 700 Series Case tractors. I'm considering buying a Model 700B with diesel engine, pto, and hydraulics. This tractor is a "standard" or "wheatland" configuration, and I want to use it primarily to swath and bale hay. I'm interested in hearing about any experiences with premature or chronic failures in the engine, transmission, or hydraulics, as well as parts availability. Does this tractor have a live pto? Thanks in advance.
MALLARD
09-15-1999 19:39:39
 Re: Early 700 Series Case Tractors in reply to John C., 09-10-1999 06:00:40
My Dad bought a 700 row crop in 1958. We had it about 12 years. The only trouble we had with it,
was fifth gear would jump out the last two years we had it. Fifth gear was the main gear we used for field work. Dad traded for a case 770.A neighbor bought the 700 then. He put a rod though
the block. I got it back, and had a guy fix the hole in the block. Now I need to restore it.
Mallard
Robert
09-12-1999 10:42:57
I had an early 730 for a while.It was identical to the earlier 700 series.The 700 should have live PTO and hydraulics.The PTO needs someone that knows what they are doing to adjust the clutch but they are a good setup.The only problem I ever heard of with these tractors was that the diesels can be reluctant to start in cold weather and that the heads can be prone to cracking.I don't know if they crack when in use or if they crack when the head bolts are loosened.
