I'm Impressed !!!!!!
Keith-OR
02-10-2005 18:23:10
I have a 1948 VAC with after market 3 pt hitch. I hooked up my Howard 5 foot triller to it yesterday, had a few things to change to get tiller to function on the VAC. Today I fired tractor up and tried out tiller, definently gave the little VAC a good work out ,BUT it was able to run my tiller. Could not run it as deep as with the larger tractors but it did do a fairly good job. I am really impressed with this VAC tractor. By the way what is the horse power of the VAC? Could not find a listing on Neb. Tractor Test..... Keith-OR
Casekernel
02-11-2005 14:12:43
 Re: I'm Impressed !!!!!! in reply to Keith-OR, 02-10-2005 18:23:10
Keith,
You mentioned an aftermarket 3-pt hitch on your 48 VAC. Just what is that (make)? I have a 49 VAC with the Kingston Hydraulics. Do you know if aftermarkets are still available and if so at what cost? Just curious.
Keith-OR
02-11-2005 18:55:22
 Re: I'm Impressed !!!!!! in reply to Casekernel, 02-11-2005 14:12:43
Not sure of the manufacture of 3 point on VAC, was on there when I acquired the tractor. Seems to work well, but I do not like the rigid lift arms, Will be changing them soon. Had to do some slight modification to my tiller so I could hook it up, cause of the rigid arms. This 3 point has 2 lift cylinders, one on each side. Maybe after I get it back home, I will post pictures of 3 point.
Keith in Gods Country
Joe (Wa)
02-10-2005 18:49:47
Keith
Test #431, 1949. Same tractor for hp rating.
Joe
Keith-OR
02-10-2005 21:01:32
 Re: I'm Impressed !!!!!! in reply to Joe (Wa), 02-10-2005 18:49:47
Thanks Joe.
