Case LA piston
Thad
02-10-2005 17:43:52
I need the compresion distance on a LA piston. The piston i need it from is one that comes to the top of the block. I have one that is below flush and one the sticks out above the top for measurements. I have looked in all the books i can find but cant find any showing old case stuff. thanks Thad
Earl S.
02-11-2005 06:47:42
 Re: Case LA piston in reply to Thad, 02-10-2005 17:43:52
Thad, I have a old Clevite book goes back in the 1950's L,LA 4 5/8 bore 2 9/16 comp height on gas with high comp head & 2 15/16 comp height for gas to 5000 alt.for kerosene or distalate above 5000 alt.For Lp use high comp head.Both flat head pistons.My old M&W book shows 2 or 3 different combo. depending on the head they are 4 3/4 & 4 7/8 bore. If you have a number on the piston I might be able to ID it, they all have dome head on piston.Maybe this will help. Earl
laipuller45
02-10-2005 19:52:35
sounds like you mite have a set of m&w pistons..may be expensive but you could send one off to a performance shop and have you a set made to order
Thad
02-11-2005 03:42:55
 Re: Case LA piston in reply to laipuller45, 02-10-2005 19:52:35
I need the comp distance of that type of piston so i can acuratly know were they are when they come flush. Then i can deduct the heighth off it that i will need to have a set of custom ones made. The problem is my crank isnt going to be 6 inch on stroke its going to be 7 or more. So i will need a shorter piston. thanks Thad
jstpa
02-10-2005 20:54:58
laipuller,
I was wondering if m&w is still in business, and if they are do they have a website. Ican't find them anywhere. Thanks, jstpa
