Case SI vs case CS
Paul Pawlak
01-10-2006 15:38:16
I'm looking for a little info on some parts that I'm going to try to sell regarding my Case SI tractor. I bought the front end off on old SC and I'm going to switch them over.I find that an SC turns with the tricle front end much easier than the wide front end SI. (MY shoulder is bad)
Ive read alot about Case SI tractors and they seem to be somewhat hard to Come by. The articles I read said that only 1000 of the SI's were made. 900 of them were a leaf spring wide front end and 100 were an I beam wide front end.I happen to have the I beam front end and don.t know what this unit is worth .The SI and SC mount up exact except for the piece of sheet metal between the gas tank and radiator cowling. The sheet metal is shorter on the SI. I'll be selling the whole thing if someone is interested. This includes the I beam front end, the sheet metal radiaor cowl( Its a bit rotted in spots) and the rims and rubber tires. I have the rest of the rear end but the rims and tires are no good.Some metal pieces are salvagable. The part that I'm concentrating on in this message is the I beam front end. If there truly was only 100 made this has to be some kind of collectable to a restorer of Case SI
You can call me at 716-937-4559 if you are interested
Paul Pawlak
PvS
01-11-2006 14:05:53
 Re: Case SI vs case CS in reply to Paul Pawlak, 01-10-2006 15:38:16
I"ve got a 48 SI with a Hough loader on it. It has the solid I beam front axle. Are you selling parts off this tractor? I need the parking brake pawl that mounts on the right brake petal.
