660 combine
ED BAERWOLF
02-09-2005 07:39:45
whatcase tractor would a engine model 201g case combine engine work in such as a 300round nose or430/530?
ED BAERWOLF
02-11-2005 08:09:24
 Re: 660 combine in reply to ED BAERWOLF, 02-09-2005 07:39:45
THANKYOU VERY MUCH FOR THE INFORMATION DON AND ELDOCASE.I FIND YOUR CONTRIBUTIONS TO THE FORMAT VERY HELPFUL AND ENJOYABLE TO READ.DON DO YOU KNOW WHEREI COULD GET A POP UP BATTERY COVER AND GAS POP UP COVER FOR A CASE 500B? THANKS
Don L.
02-12-2005 19:25:59
 Re: 660 combine in reply to ED BAERWOLF, 02-11-2005 08:09:24
I have the small 6 inch wide covers , but not the ones that are as wide is the hood.
Don L.
Jerry W
02-10-2005 12:27:06
It will also give you the most powerful VAC in the neighborhood, but you do have to 'rearrange' the sheetmetal to fit with the longer motor.
Jerry
Eldo case
02-10-2005 07:30:06
I have one in a 500b. One powerhouse! It is one inch longer. Will also fit in where a 188 came out.Won't fit in a round nose.
Don Livingston
02-10-2005 07:29:51
Best place to put it..... is to use it as 188 diesel replacement [430,530,630] or a 630 gas. Your combine motor is 1 inch longer than the 200/530 gas motors.
