Case Engine
J Kelnhofer
02-08-2005 20:45:35
I Just put new o rings on my 930's sleeves, and when I drove them in, they were really difficult to get them all the way down, I had to really wail on them. Should I be worried about the o rings not sealing right? Is it possible that the o rings could pop out of their grooves in the sleeve? Advice appreciated. Thanks
C_BUNTING
02-09-2005 07:12:33
 Re: Case Engine in reply to J Kelnhofer, 02-08-2005 20:45:35
Here is What I have learned.
1. Make sure they go in dry with out O-rings.
2. Feel the bock for a tiny rust ring and use some
fine sand paper to remove any tiny lumps or bumps.
3. The Case book says use "Ivory Soap" but all the above comments are good.
RobertTX
02-09-2005 05:14:41
Rust builds up around the bores where the rings seat. It is often very hard to remove, will make it difficult to seat the sleeves.
John Saeli
02-09-2005 05:00:41
Hey J. It's most impportant to have the bores clean. With no "O" Ring on them, they should fall to the bottom. Allen is correct, some kind of lube is needed. I use old Veggie grease, (just because I have it). Murphy's oil soap has been recommonded. Any non-petroleum type lube.
Allan C
02-08-2005 20:50:41
Didja put some sort of slidem like vaseline on them when you put them in? If not they could rollout of the groove and get cut.
Doc Larry
02-09-2005 06:50:34
 Re: Case Engine in reply to Allan C, 02-08-2005 20:50:41
One of the best lubricants for o-rings and other rubber seals is a liquid hand cleaner like GoJo. In most cases the sleeves will snap right into place.
Larry
