Case 580 C hot brakes?
jpdale
02-08-2005 18:37:08
I have a 580C and just noticed that after moving the machine a short distance the right side brake housing gets very hot. The left side is bone cold. Is this normal? Is the right side out of fluid(if thats possible). Any ideas or suggestions?
Both right and left brakes work fine.
MickK
02-09-2005 14:24:49
 Re: Case 580 C hot brakes? in reply to jpdale, 02-08-2005 18:37:08
Look for the obvious, is the adjustment way out on one side as compared to the other. On top of the brake there is an adjusting screw, if this winds iteself up too far it will start to pull on the brakes.
This is a self adjusment as well, so look at the little finger that turns the screw, make sure its not clogged with crap and working freely.
Is one pedal higher than the other?
You may need to pull the housing cover off and check if there is a lot of brake dust in there. It may just need a clean out.
Good luck in sorting it out
Mick
jpdale
02-10-2005 05:39:38
 Re: Case 580 C hot brakes? in reply to MickK, 02-09-2005 14:24:49
Thanks I will check out the adjusters.
I talked to the previous owner and he said the dealership just replaced the brakes on that side! I hope they didn"t do something wrong.
