580 C Torque troubles
rwf
02-08-2005 18:19:19
RPM's run high in 3RD and 4TH gear and acts like clutch is slipping. Had the shuttle rebuilt which made very little improvment. I am told now that the torque needs to be replaced. Was also told that it could be rebuilt too. Has anyone had this done?
MDSKY
02-09-2005 16:25:30
 Re: 580 C Torque troubles in reply to rwf, 02-08-2005 18:19:19
It sounds like you are on the right track.Generally when one of my converters went bad ,there were a lot of metal shavings in the pan.Make sure you flush the oil cooler when you service the trans and converter. good luck
Greasey Hand
02-26-2005 07:45:25
 Re: 580 C Torque troubles in reply to MDSKY, 02-09-2005 16:25:30
There is a rebuilt one I know of at a case place for $1070.00 Send me your E Mail address & I'll give you the phone no.
GreaseyHand
02-26-2005 07:34:30
Im going through a 580 CK now, Went through the shuttle, things were bad Alum drum, O rings, springs in clutch hubs were broke, Going through the converter there was lots of shavings, The big part is the the bushing in the pump drive gear & the carrier assy, They wear & you loose pressure.
The carriers no longer avalible from case. You wouldn't want to that much for it anyway.
I have had these rebuilt.
The shaft that goes through the converter can be bad where the locking oil rings are, Grooves
get wore.
Good parts are hard to find,
I have found that salvage yards sell parts & there good to them, They dont look at them good enouph & Dont know where & what wears & has to be in very good shape to work, They are not a Mechanic.
