antifreeze in oil
todd66
02-08-2005 15:59:58
I have a Case 930 comfort king diesel. Found antifreeze in the oil. Took off oil pan and heads and found antifreeze leaking into the pan from the #3 cyl sleeve "o" ring. Took out sleeve and there are rust pits in the block where the "o" ring should seal. Any repair suggestions?
John Saeli
02-08-2005 16:45:20
 Re: antifreeze in oil in reply to todd66, 02-08-2005 15:59:58
Hey Todd: C Hess is right on the money. J.B.Weld will work fine.
c hess
02-08-2005 16:25:46
fill holes with jbweld .use sparingly . wery hard tosand or file excess away. you could also have a sleve put in but that requires machine shop work. very expensive. jb weld does work
