Case 311 Transmission hydraulic oils
railroadgoat
02-08-2005 13:56:44
Case 311 Where is filler plug for hydraulic oil ?? Takes 12 quarts of 10-30w, correct ??
Transmission and rear end, are they together ?? Oil fill plug for them ?? 24 quarts of 90w ??? Drain plugs for each under tractor, I presume /?
You guys know you have a dummy here !!!
railroadgoat
02-08-2005 14:41:19
 Re: Case 311 Transmission hydraulic oils in reply to railroadgoat, 02-08-2005 13:56:44
[email protected]
John Saeli
02-08-2005 15:11:16
 Re: Case 311 Transmission hydraulic oils in reply to railroadgoat, 02-08-2005 14:41:19
Hey RRGoat: I find that a blend of Trans-Hyd Fluid & 85W140 work good in the Front Housing where the Range Box & Hyd.'s are. After 50 years, parts are sure to be wore, and the thicker oil helps. I blend 50-50. Straight 85W140 for the Rear Housing.
Case300
02-08-2005 14:07:24
Hey railroadgoat, where'd you get that name????? ?Nice. Any way the the torque tube is where the hydraulic oil is. there's a plug in the bottom to drain it and one on top to fill it. Most people I believe use the modern universal hydraulic fluids for in there. and trnsmission fluids also. The transmisson is in what's called the rear end. Email me your address and I'll send you a copy of a Case service chart for that tractor. Has the types of oil, intervals,locations etc. No charge.
