rocker arm pushrods 51 case SC
DWhittemore
02-08-2005 13:54:07
anyone know where I can get rocker arm and set of push rods for my 51 sc..Can the crankshaft be removed without taking the motor completly out.Thanks for your reply. Dennis Fla.
JA in OK
02-10-2005 18:07:58
 Re: rocker arm pushrods 51 case SC in reply to DWhittemore, 02-08-2005 13:54:07
I have a set of pushrods and rockers off a "47 SC if you dont find any elsewhere. Email me if interested. By the way anyone have a 3 1/2" sleeve for a SC?
DWhittemore
02-13-2005 01:10:15
 Re: rocker arm pushrods 51 case SC in reply to JA in OK, 02-10-2005 18:07:58
hey JA of OK,looks like I need those push rod for my 51 SC,does your 47 push rods work on my 51 sc?what is your cost. Thanks Dennis
JA in OK
02-15-2005 20:32:53
 Re: rocker arm pushrods 51 case SC in reply to DWhittemore, 02-13-2005 01:10:15
I will take $50.00 for the rockers and pushrods. I am going to be leaving town tomorrow. I unblocked my email. Please contact me and will arrange something.
C. Amick
02-11-2005 05:16:30
Try Don L. ([email protected]), he had some used SC sleeves a while back, but I don't know what size they were.
C. Amick
02-09-2005 13:48:38
If you don't find the parts you need on Ebay, email me and I can give you some other sources.
C. Amick
02-09-2005 13:37:56
No. The crankshaft must be unbolted from the flywheel and you would not be able to get the engine back in time when reinstalling the crankshaft without removing the timing cover.
DWhittemore
02-09-2005 16:45:03
 Re: rocker arm pushrods 51 case SC in reply to C. Amick, 02-09-2005 13:37:56
Mr.Amick,I have the timing cover off , so,all I now split the motor,disconnect clutch and the crank from the flywhell,unbolt the rods from the pistons ,the crankshaft should come out????? Thanks for your reply. Dennis Fla.
C. Amick
02-10-2005 06:07:20
 Re: rocker arm pushrods 51 case SC in reply to DWhittemore, 02-09-2005 16:45:03
Yes, after you unbolt the 3 main crankshaft bearings. Be sure to put the bearing caps back on at he same location as they came off and keep them turned the same direction. I would also mark the rods and put them back in the same cylinders they came our of. The rod bearing caps face toward the camshaft.
Mark in Iowa
02-08-2005 17:01:22
Go to e-bay....theres a sc in pieces for bid..I'm sure there was pushrods & lots of other stuff... In e-bay go under "case tractors sc" .. hope this helps....Mark
