serial no. for an 930 wheatlander
max e
02-08-2005 06:46:15
hey guys where might i find the serial no. in order to get paint from is this the same as the no. on the engine block? thanks max egolf
Brangus1
02-08-2005 19:21:05
 Re: serial no. for an 930 wheatlander in reply to max e, 02-08-2005 06:46:15
What is a " Wheatlander " and/ or a " Western Special " ?
Roger H
02-09-2005 07:06:52
 Re: serial no. for an 930 wheatlander in reply to Brangus1, 02-08-2005 19:21:05
Brangus, do you remember the pics I sent of my 930 with the loader? my 930 is a western special, it has bigger fenders & the reversed front axle & wide swing drawbar instead of a 3pt hitch.
Roger H
02-08-2005 07:13:05
If you have an early 930 the tag should be on the right side of the dash ahead of the key. If it is a later 930 it should be down below the dash ahead of where you might rest your left foot, just ahead of the clutch pedal if it has a foot clutch. The number on the engine tag is for the engine only, it is not the same as the tractor number.
