Autolite 3116 plugs heat range??
JW
02-07-2005 19:18:09
I bought a set of 3116s for my 830 and was wondering if anyone knew the heat range on them. I have been using UD16 Champions. Tractor uses no oil and does everything from idleing to hard work so I don't want a very hot plug.
Roger H
02-08-2005 07:18:23
 Re: Autolite 3116 plugs heat range?? in reply to JW, 02-07-2005 19:18:09
Throw the Champions away, if I remember the 3116 is what is in my 930 gas. Champ. D9's is what is called for in my 830 propane but I will NOT use Champions again
sc man
02-08-2005 05:14:06
If I was you I would stick to champoins plugs the other plugs file out to fast thats my .02 cents worth
JW
02-08-2005 06:01:32
 Re: Autolite 3116 plugs heat range?? in reply to sc man , 02-08-2005 05:14:06
We have had the opposite around here. Our Case- IH dealer no longer handles Champion because of poor performance, they switched to Motorcraft. I personnally have not seen any real advantage from one brand to the next.
sc man
02-08-2005 07:57:17
 Re: Autolite 3116 plugs heat range?? in reply to JW, 02-08-2005 06:01:32
well i had trouble with autolite in my sc and my case ridding tractors and i willnt use them anymore
John Saeli
02-08-2005 15:20:35
 Re: Autolite 3116 plugs heat range?? in reply to sc man , 02-08-2005 07:57:17
Autolite's are the only plugs we use around here. No more plug fouling with the 3116's. I wouldn't have a Champion on the place.
