Thrust Washers /and pins
Ron Lewis
02-07-2005 16:55:48
I have a 56 VAC 14 Case Tractor
S/N-6001912 Continental engine.
I'm trying to install the thrust washers.The pins
in the front are too short to hold the thrust washers.Where can I get new ones? And how do I remove the old ones?
Next question.are the washers supposed to be flush against the block?
Question No. 2 The book says to install the chamfer towards the rear.Which seems OK.but should'nt the washer on the crank be towards the front.
Need Help
Ron
C. Amick
02-09-2005 13:52:55
 Re: Thrust Washers /and pins in reply to Ron Lewis, 02-07-2005 16:55:48
You might try Don L. at: [email protected] for parts.
