VAC seal
KY. Ted
02-07-2005 13:17:35
Have a 1950 vac and hyd. fluid is leaking from the torque tube into the clutch housing, i know it needs a new seal, has anyone else done this and how much trouble is involved. thanks for all the help in the past Ted.
Augie
02-07-2005 17:31:27
 Re: VAC seal in reply to KY. Ted, 02-07-2005 13:17:35
Did that weekend before last. Off the top of my head the seal is a CR12456.
It's not too bad of a job. Split at the front of the torque tube, remove clutch shaft quill, replace seal, reassemble. Check for end play on the clutch shaft before you remove the quill - if there is end play you'll want to remove shims to tighten the bearings when you reassemble.
Email is open if you have questions.
